All ten forward gears and two reverse gears can run in 4 wheel drive. Power comes from the top side of the 4th gear slider on the main shaft. All gears on the mainshaft rotate in the same ratio as the rear wheels. Any gear could be used but 4th is closet to the Elwood gear box which replaces the belt pulley gearbox.
A 660 Elwood sold last month for $16,500 at a PA auction. Click below for completed listing.
The Elwood kit will fit all the way back to '39 M and corresponding W models. The gear that meshes with the 4th gear slider may have to be changed. I dunno. Otherwise it is a bolt on attachment.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
