You need to see if there's fire to your plugs. Pull off a plug wire and have someone make an attempt to start the engine. If there's no fire and this is a distributor you should have battery voltage on both small terminals on the coil with the ignition switch on and points open. If there's voltage here remove the coil wire from the cap and hold near a good ground while someone snaps those points open and close a few times. Need the switch on. If there's no fire change the condenser and rub those points with some 320 wet or dry. hal
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
