The location of the hydraulic valve may be a red herring here.
It would be very rare to find a Stage II Super M that started life with a belly pump, then had all the Stage II acoutriments added later. Not impossible mind you, but not likely, either.
Bob M can confirm this, but if memory serves, the standard location for the "christmas tree" valve on a Stage II Super M is that spot where the fill pipe would have been for the belly pump. The valve mounts on a special elbow that either screws into the fill pipe hole, or has a flange on it that allows it to be bolted to the tractor.
There was also an aftermarket type valve that mounted in that general area too.
The original poster needs to take a closer look at what he has. With a christmas tree valve, you'll likely find a hose coming out at the base and running back to the under-tank reservoir.
On the Super H Stage II for comparison, the christmas tree valve mounts directly to the reservoir with a pair of elbows.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
