Posted by mkirsch on January 15, 2009 at 09:46:27 from (64.80.108.56):
In Reply to: Farmall M wont start posted by Kelly001 on January 14, 2009 at 17:22:44:
OP said he replaced the coil.
If you wire the coil backwards you'll get a weak spark and the tractor won't run.
If you get a 12V coil with internal resistor by mistake on a 6V system, you'll get a weak spark and the tractor won't run.
Do the old trick your dad taught you with the lawnmower: Pull the plug, put it back on the plug wire, lay it against the engine, and crank it over. If you get a bright blue spark, it's on to the next piece of the puzzle. Weak and yellow, and you've got your problem narrowed down.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
