Re: Stage II Super M Hydraulic question
Posted by D Slater on January 15, 2009 at 09:58:48 from (71.164.51.74):
In Reply to: Stage II Super M Hydraulic question posted by biggerred on January 14, 2009 at 19:19:22:
If tractor is a stage 2 and was equiped from the begining with live hydraulic and has the original type remote control valve there is a bolt with special washer accessed from inside center housing that holds valve tight in hole. Also used a cover on bottom of housing that looked like bottom of a belley pump. If the piece bolt goes in is there it will be hex shaped like a big nut just on top of housing where fill pipe goes in on regular belley pump. If you do have a belley pump inside housing we will need more information because something wouldn't be original. All stage 2 didn't come with live hydraulics, also does the starter mount with 3 bolts?
