Re: Oil Change
Posted by rustred on January 15, 2009 at 13:37:27 from (209.115.232.65):
In Reply to: Oil Change posted by Farmall Ed on January 15, 2009 at 06:07:14:
not questioning your oil changes but i am just wondering about something. do you lube the filter 0 ring with a film of oil,use grease on it, or put it on dry. i lube it with oil and have had none stick. the other two options i have seen them stick and be hard to loosen.not counting over tightening them.this is my experience during the years.
