Re: SuperA's
Posted by Old Ford Mechanic on January 15, 2009 at 13:53:45 from (75.254.247.64):
In Reply to: SuperA's posted by Collins on January 15, 2009 at 13:37:44:
Serial # should be on left side of clutch housing.There is also a number on the engine block just above the hydraulic pump.Right at the top of the block just below the cylinder head.If it is the original engine block you can date the tractor using that number.
