Re: Farmall H Battery Installed backwards
Posted by Antgre on January 15, 2009 at 14:27:00 from (71.55.159.160):
In Reply to: Re: Farmall H Battery Installed backwards posted by Antgre on January 14, 2009 at 18:27:23:
When I disconnected the BAT terminal on the cut out switch the drain went away. I took the cover off and tapped on the contact a few times and when I put it all back together there was still no discharge. So it looks to me like a sticky relay.
When I looked for the cut out on CaseIH.com I could only find it listed under the magneto ignition section. Also, when I called my local Case dealer they said, "These tractors didn't come stock with a cut out switch so someone must have replaced the regulator with one." Is that true? Should I just get another cut out switch or should I get a voltage regulator?
