You have a lot of good advice to sort through already but I will add this.
You kind of slid over if the battery ran down before or after the tractor would not start. Did you run the battery down trying to start it or did it not start because the battery ran down while you were running it.
Is it a distributor or mag.
When you run across a situation like this it's best to start as close to square one as you can. In this case it sounds like its the battery. I would charge it up full then see if the tractor will start, if it does then I would use all the excellant advice you have received here to make sure the gen works and then the wiring.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
