Re: Farmall H - HARD starting
Posted by old on January 15, 2009 at 21:22:26 from (4.244.57.36):
In Reply to: Farmall H - HARD starting posted by Kippster on January 15, 2009 at 20:33:37:
Does the impulse in the mag work as it should?? If you can not hear it trip or it only trips once in a while that would make it very very hard to start
