Re: W4 motor
Posted by Andy Motteberg on January 15, 2009 at 21:22:39 from (4.143.216.14):
In Reply to: W4 motor posted by Followers of weber on January 15, 2009 at 12:32:29:
Yes, they both use the C-152, just have a few different changes between the W-4 and H. The W-4 has a different timing cover and the governor arm is different. A few of the parts on the outside are slightly different, but it is pretty much the same engine as the H.
