Don't panic yet.
Posted by usetabesteve on January 16, 2009 at 07:28:27 from (168.166.54.11):
In Reply to: Farmall H - HARD starting posted by Kippster on January 15, 2009 at 20:33:37:
These old tractors were and are still pretty forgiving - extreme precision is not necessary to get one runing well. Start with the simple things. You may not have that much difficulty fixing this.
When an engine needs the choke to run smoothly, you have a too lean mixture. You may have a vacuum leak or you may have something worng with the carburetor, but you might try opening up the mixture valve first.
The starting easier on a hill probably means that the float level is too low - another easy fix. Setting the float level is not intuitive at all, so follow the instructions in the manual to get it right.
