Re: IH M with Aux 9 Speed Transmission.
Posted by Janicholson on January 16, 2009 at 08:12:30 from (199.17.6.128):
In Reply to: Re: IH M with Aux 9 Speed Transmission. posted by Tonybackache on January 16, 2009 at 07:08:56:
Fifth is always direct drive (input shaft to output shaft) the 9 speed changed the ratio of the countershaft. Thus there were in sequence of slow to fast 1 low 2low 3low 4low 1high 2high 3high 4high 5th.
The 9speed filled in the gap between 4th and 5th.
Low in the above description is standard gear ratios as made by IH. High results from the 9 speed. JimN
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
