Re: Farmall M fouling plugs
Posted by old on January 16, 2009 at 09:01:27 from (4.244.186.18):
In Reply to: Farmall M fouling plugs posted by Matt Gjerde on January 16, 2009 at 08:31:01:
If it is in fact running that rich you have a problem and that rich could be causing wash down in the cylinders which is as bad as running to lean or even worse. I would take the main jet and screw it all the way in, then back it out about 4 turns. Adjust for max. power with no black smoke and fine tune it from there to the point you have good looking plugs and good power. Running the rich is probably hurting your engine because the extra gas is washing the oil off the cylinders and hurting the rings and pistons
