Posted by GordoSD on January 16, 2009 at 10:03:42 from (66.115.200.140):
In Reply to: Water in transmissions posted by Idaho Ron on January 16, 2009 at 09:57:11:
When I replaced the cover bolts I put a flat washer on the bolt, then a really tight fitting HD O ring under that. Plus a little RTV at the top of the bolt. I know the tapped holes don't go all the way to the tranny cavity, but if they fill up with water, It can travel sideways and then down. Some of it is condensation. But I had a SMTA that i drained and refilled with new hytran, NEVER ran it at all but it sat out for the winter. Sure enough that spring I had a bellyfull of water.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
