Re: Water in transmissions
Posted by glennster on January 16, 2009 at 10:06:37 from (76.223.245.56):
In Reply to: Water in transmissions posted by Idaho Ron on January 16, 2009 at 09:57:11:
one way is from condensation, when there is a temperature change, it draws the moist air in and the water condenses inside the trans/rear end case. another is thru the shifter, and then thru bolts on the deck. working on a farmall m right now, there are at least 2 bolts that go thru the deck into the trans, first is the far left front bolt on the deck by the clutch pedal, the other is the left bolt that holds the steering post down.
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
