The Mazda pump adaptation looks pretty good - almost like it was factory made. Presuming it has enough capacity to supply the torque motor you plan to use (Charlynn?) I suspect it would work well and be trouble-free.
However the Toyota electric pump I'd avoid for a couple reasons:
1 - You'll need a 12 volt alternator conversion. Also the alternator would need to be fairly high-capacity (60 amp or greater) to work well.
3 - I'd be concerned about the electric pump's longevity in tractor service! Keep in mind in a car that pump probably runs only occasionally and very briefly - like when parking. However on your average tractor the power steering (and hence the pump) must work hard pretty much continuously. I suspect the pump motor would heat up quickly and not last very long.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
