Re: 560 hydraulic pump
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Les Repair on April 03, 2000 at 18:56:31 from (206.28.174.169):
In Reply to: 560 hydraulic pump posted by sjk on April 03, 2000 at 15:09:44:
The unloading valve isn't letting the system go off pressure. This is normally worse as the oil vgets hotter. To get to this, take the shield that covers the hydraulic off. Toward the left of the valves is a box with a cast cover about 2 by 4 inches. The cover is held on by four bolts which use a 1/2 wrench. Take this cover off. Under this cover you will find a plug which uses a flat screwdriver to remove. Take the plug out and enlarge the small hole in it with a 1/64 drill bit. Put it back together and it should work. 515 847 2731.
Post A Followup
: Re: Re: 560 hydraulic pump
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
