Re: magneto to coil conversion
Posted by Janicholson on January 16, 2009 at 15:33:42 from (66.173.50.68):
In Reply to: magneto to coil conversion posted by J. V. Matthews on January 16, 2009 at 07:36:07:
If you are willing to remanufacture the Mag cap, you might be able to drill a hole into the cap to allow the high tension wire from the coil into the center to get to the rotor. Haven't seen it on that mag, but If I was set on doing it I would try it. Another possible solution is to use a 4 cylinder distributor from any of various cars or tractors (IH included) that turn in the right direction. Make a drive adapter to fit the engine, and a wooden or metal support to position it in alignment on the existing Mag mount. JimN
