Re: Loader for farmall H
Posted by Andy Motteberg on January 17, 2009 at 12:11:37 from (4.143.220.164):
In Reply to: Re: Loader for farmall H posted by Dan J 13655 on January 17, 2009 at 03:50:07:
Dan, I had a problem with my loader not raising up very high when I got it. I found out I needed a hose going from the hole in the top of the cylinder, to the belly pump filler. Do you have that on yours? You might have a plug on the end of each cylinder. Fill the hole with oil and thread a hose into the hole, thread the other end of the hose into a 4-way fitting on the belly pump filler, do the same on the other cylinder. As the loader goes up, the oil in the top of the cylinders will be pushed into the belly pump and pumped into the bottom of the cylinders so it has more oil to raise up high. Wen you lower the loader, the extra oil in the belly pump goes back through the hoses and back into the top end of the cylinder.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
