You should pull the engine and see if it can rebuilt unless the block is somehow broken. You can get it apart even if its stuck. I would want to use the original block if possible. Get it running then determine how much restoration you want to do. See if there's any leaks from the gear boxes. I would drain them as they may be full of water. You may want to replace the clutch while you have the engine off. Give it a good cleaning with a pressure washer. A paint job will make it look new. Hal
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
