Posted by Janicholson on January 17, 2009 at 16:42:50 from (64.83.227.252):
In Reply to: 460 out of time!!! posted by A.M.'s 861 on January 17, 2009 at 15:59:02:
Take out the plugs,and ground the coil high voltage wire against the block to prevent high voltage from finding you. Put your finger, or a rubber hose, in the #1 hole (closest to the radiator) and turn the engine By hand, or starter bumps, until air is felt coming out of it. this is compression stroke. Turn by hand from here until the timing marks are aligned. The distributor cap now needs to be removed to see where the rotor is pointing. It must be pointing to #1 exactly. This assures the spark is getting to the correct cylinder. Then check the remaining wires to assure the correct firing order. If this is OK I would next see if there were good strong suction on the intake when cranking. Place your hand over it to feel the suction. If these check out, see if the fuel supply is getting to the carb. Let us know what happens after this. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
