Bjarne, please check casting codes on the rest of the tractor to help clarify the discussion below. They will be in the form of 5*8*U, or May 8, 1951. U and W are 1951, X is 1952. Apparently yours was made in 1 of those 2 years. Casting codes are on most parts. Compare the engine casting code with other parts. If the L is in the form of month*day*L, it was cast in 1942. If there are no other L's then it is a replacement. One other thing. Some SUPER M's were built in Louisville. A stand alone L is an indication that the part was cast in Louisville (although some parts could have been shipped to Louisville and then assembled) The FBK prefix indicates that you have an M not a Super M (at least the engine is from an M), so if the L on the axle housing is NOT in the form of month*day*L, and is by itself, that casting may be from a Super M.
Today's Featured Article - Antique Tractor Wiring Basics - by Curtis von Fange. One of the most neglected parts of old tractors is the wiring. After sitting in the elements for half a century or more much equipment wiring has deteriorated to sparsely covered strands of copper or other metal. Plastic insulation has cracked, mice have eaten through the older clothed style coverings and the exposed wires have reacted to winter moisture and salts by turning blue and powdery. Terminal ends have corroded, rusted or just plain evaporated away. Aged wires not only keep an engin
... [Read Article]
Latest Ad:
1953 Ford Jubilee Tractor. Last driven 5 yrs ago. Parked ever since. As is as seen
[More Ads]
