Re: Flashers
Posted by Janicholson on January 17, 2009 at 19:55:08 from (64.83.227.252):
In Reply to: Flashers posted by Kevin Brambrink on January 17, 2009 at 19:02:17:
A 12 gauge wire from the battery side of the starter switch going to A 15 amp inline fuse holder. From the fuse, go to a 20 amp capable switch. (located where you can reach it. From the switch 12 ga wire to a 6 (or 12) volt heavy duty two prong flasher. From the other flasher prong, go to all the lamps you want to flash. use 12 ga wire if 6v. or 14 ga if 12v. Ground each light at the mount to the tractor, and there you are. JimN
