Re: H overhaul
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by jakee on April 03, 2000 at 20:37:05 from (152.163.201.202):
In Reply to: H overhaul posted by super M on April 03, 2000 at 13:10:40:
you need to bore block to put super kit in it,there was a size made between the H and super H.the 3 5/8ths kit will have to use at least a super h -300-350 block they were cast thicker.if you use the H block you will bore threw into the wayter jacket at the bottom,with a .003 press 3 5/8ths sleeve will work,but each time you redo it you will have to press a new one in it,we have went as far as a 4 inch bore,but that gets real chance for tractor pulling.
Post A Followup
: Re: Re: H overhaul
