Drove me nuts too (656 gas). I was installing replacement intake and exhaust manifolds and couldn't figure out which way to install the replacement spring. I used a propane torch to heat it up, watched it work while temporarily attached to shaft, etc. but it just never moved the flapper in the correct direction.
Eventually gave up trying to install it. Since I live where it's warmer I fabbed a thin sheet of steel to replace the gasket and totally sealed off the chamber. Bad idea (as a poster here warned me about immediately after I did it.) Took TOO long to warm up, even on a decent day.
This fall when timing the valves I gave it another go. Got the propane torch out again and studied the problem. Turns out either the spring WAS wrong or they forgot to put a bend in it. I added a little loop to the spring, (the loop you see going around the post that sticks out of the manifold) and it now works perfectly. If you are installing the shaft and a new plate at the same time be careful with the welder. I thought it would be smart to run a bead to attach the flapper to the shaft instead of just tacking it. WRONG. I warped the shaft a little and had to work it a while before it would let the counter weight do it's thing again. The attached pic was taken with the engine cold. You can just see the top of the counter-weight peaking out over the top of the exhust manifold.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
