I was planning on using my 560 ...It needs a new pump so Im going to put a 17 gpm pump in it....would that still not be enough for two hyd motors??
I had thought of a pto driven pump on the spreader but thought the tractor pump may work saving buying a pump and making a resevoir...I have some shafts.....
My thought with hyd drive is that it will be easier to calibrate what application rate I want ....originally thought of ground drive but would have to keep changing sprockets to get what I want rather than turning a valve...plus I have the motor/auger setup....
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
