Re: How to remove top transmission for a 1942 Farmall H
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by The Red on April 04, 2000 at 05:25:11 from (12.75.221.22):
In Reply to: How to remove top transmission for a 1942 Farmall H posted by buster on April 03, 2000 at 16:20:40:
Buster, I would go with Medfarm and Dale's suggestions first. If that is not the problem, then you have a half day's work ahead of you. You will have to remove the steering column, seat, rear light, gas tank and the belt pulley assembly if you have one. Then you can unbolt and pull the decking. Careful it is heavy. Also I hope your bolt heads are not too corroded on the deck. Let us know what you see about the shifter and forks before you go further.
Post A Followup
: Re: Re: How to remove top transmission for a 1942 Farmall H
