Re: Another crankshaft question!
Posted by spiffy1 on January 18, 2009 at 09:30:09 from (70.41.137.72):
In Reply to: Another crankshaft question! posted by Old-F20 on January 17, 2009 at 22:45:01:
Never used the Plastique brand, so I'm not sure how they compare. In the Plastigage brand, I tried green .001 to .003 once (quite a few years back last I did one of these though!) along with red .002 to .006 but really drove myself nuts, so I only bought red this time. Maybe, I should grab some green when I'm in town again - if for no other reason than so I don't wish I had!
I like your idea of using the 3 pieces at the same time! Do you add the two side #'s together and trig the horizontal backward from that and the bottom or just use it to direct a gut feel? No doubt still time consuming, but like I noted, I remember really driving myself nuts with a piece in the bottom, then in the side, then feel how it cranks (with the others loose and spark plugs out), then adjust shims..... and again..... and again! :lol:
