Re: Farmall M Serial number again
Posted by CNKS on January 18, 2009 at 10:43:23 from (216.144.104.128):
In Reply to: Re: Farmall M Serial number again posted by Jim Becker on January 18, 2009 at 10:08:27:
Jim, although "most" date codes are separated by "screw heads", as you know not all are. When I first looked at the date code, I thought it read 7 10 L with vertical lines between the numbers, now I'm not sure. But if it is 7 10 L, that and the other code on the axle housing pretty well match. BUT, I forgot that R part numbers were not used that early. In the M parts book none begin with 100 (if I'm reading the R1 part number right). Looking again, it looks like 1C0185 R1, which also does not fit any IH codes of that era. So maybe it is a British? tractor. This thread kind of opens a "can of worms". I think we need a picture of the whole tractor, maybe you or D Slater or someone can identify it.
