Re: Farmall 756 Steering Wheel Removal
Posted by mkirsch on January 18, 2009 at 12:22:07 from (67.240.251.254):
In Reply to: Farmall 756 Steering Wheel Removal posted by rrogers on January 18, 2009 at 10:00:40:
John,
They make a specific tool called a steering wheel puller that is designed to do the job. Cheap ones are cast pieces that look like the inside of a peace sign (A Y with the extra leg).
The casting bolts to those smaller holes you mentioned, and a larger bolt in the center pushes on the shaft to pull the steering wheel off.
