Re: Another crankshaft question!
Posted by rustred on January 18, 2009 at 14:19:10 from (209.115.232.65):
In Reply to: Another crankshaft question! posted by spiffy1 on January 17, 2009 at 22:45:01:
just wondering if you got it? if you have any where from .0015 to .003 clearance it is good to go, yes it only turns 1050 rpm so i would say it will out run you. it is not real critical to have these specs. right on. i bet there is some of these tractors out there running with maybe .010-.015 clearance. its if you put him to work you want things on the tighter side with hot thin oil. you could also go with straight #40 oil.
