Posted by ChadS on January 18, 2009 at 14:22:12 from (4.224.78.70):
In Reply to: Re: low $ H stroker posted by ChadS on January 17, 2009 at 18:41:20:
45 hp. Take the H block, and have 350 sleeves installed. Requires block boring, but still uses a stock IH sleeve. It will still run with full water and will be just as good as stock. It will be a 3-5/8 sleeved bore, which makes 175ci. Take the H head, and have it checked to see how thick the plate is. This will tell you about how much you can mill off and still be safe to use. I would recomend being conservative, machine .020 off it and put it together. Should make 43-45 hp with pump gas and a M carb. No stroking involved.
A 350 piston can be stroked a little. It would be the same kind of upgrade, spec wise as the M&W strokers for the M-450. 4.75 stroke, have the tops recut to fit the head, and you would have a nice workable H with a bit more, and still use IH parts when it comes time for rebuilding. You would be looking at running higher octane fuel with a stroker, unless you was to build the stroker, then set a kerosine head on it, then you should be able to run 87 in it. You should be able to build something like this for 2000 or less. JMHO, Hope this helps. ChadS
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
