Re: Janicholson on mag conversion
Posted by Janicholson on January 18, 2009 at 17:47:32 from (66.173.50.11):
In Reply to: Janicholson on mag conversion posted by JMOR on January 18, 2009 at 15:32:19:
Whew, That mag is decidedly bizarre inside. My thoughts were just to get an operational spark, but I guess not on that unit. As to the polarity of spark. I agree the only small advantage to a center to ground spark is the thermionic effect of a hotter point of origin.
The plasma between the electrodes just needs to start a good fire.
Several years ago an extreme test was made with consumable electrode high current Capacitive discharge. (I have no idea where it was published) This experiment used currents of 20 to 100 times those found in normal spark ignitions.
It actually produced a flash of superheated gas into the chamber (test cylinder) that produced a significant improvement in combustion rate and flame travel due to a larger flash origin for ignition. The peak mean effective pressure was greater, and power was incrementally increased.
It was determined that the cost of consumable electrodes, and the complexity coupled with metal being "eroded" off of the tips, was not a viable solution. CDI and other hot spark electronic igniters and coils pumping into wider spark gaps (some at .080") are a reflection of the value of the idea. Exotic metals and heat control are also in the same realm of applied science. Fun discussion. His rebuilt mag looks great. I hope it performs. JimN
