Re: H Liftall tied back
Posted by Curt from MN on January 18, 2009 at 17:47:59 from (72.2.207.20):
In Reply to: Re: H Liftall tied back posted by Dave in CT on January 18, 2009 at 17:20:22:
Schwartz 1100 trip loader. May change it over to all hydraulic but don't have the bucket cylinders yet. Line to the spool is on the left front pump outlet. Lines for the up and down actions are from the spool to tee connections splitting to each cylinder connection under the tractor. Return line from the spool to the belly pump via the fluid fill hole with a tee allowing filling of the pump reservoir if need be. Driveway fills in about as fast as I can push the snow back out. Had an auxiliary tank plumbed in but decided that slow response of lift was maybe due to fluid not being able to return quick enough to the pump or that the pump didn't like being so full all the time and needs some air space to function properly. Is working much better now but could also be the 40 degree change in temps? Before taking the external tank off the fluid would turn foamy and couldn't hardly lift even the empty bucket. Today was able to lift fully loaded bucket. Now if I can just get the trip to function correctly when I want/need it to. Like this loader as it is low profile and I can get easy access to fuel the tractor.
