Janicholson said: (quoted from post at 21:47:32 01/18/09) Whew, That mag is decidedly bizarre inside. My thoughts were just to get an operational spark, but I guess not on that unit. As to the polarity of spark. I agree the only small advantage to a center to ground spark is the thermionic effect of a hotter point of origin.
The plasma between the electrodes just needs to start a good fire.
Several years ago an extreme test was made with consumable electrode high current Capacitive discharge. (I have no idea where it was published) This experiment used currents of 20 to 100 times those found in normal spark ignitions.
It actually produced a flash of superheated gas into the chamber (test cylinder) that produced a significant improvement in combustion rate and flame travel due to a larger flash origin for ignition. The peak mean effective pressure was greater, and power was incrementally increased.
It was determined that the cost of consumable electrodes, and the complexity coupled with metal being "eroded" off of the tips, was not a viable solution. CDI and other hot spark electronic igniters and coils pumping into wider spark gaps (some at .080") are a reflection of the value of the idea. Exotic metals and heat control are also in the same realm of applied science. Fun discussion. His rebuilt mag looks great. I hope it performs. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
