Re: Advice when buying an M
Posted by Red Mist on January 18, 2009 at 19:18:18 from (67.142.130.29):
In Reply to: Advice when buying an M posted by EZ on January 17, 2009 at 17:35:18:
One final thought..... if it runs good enough to verify, be sure to check and make sure it stays in 5th gear (doesn't pop out of 5th while driving it). That can be an expensive repair. It is caused by operators grinding 5th while shifting up from 4th and not making a clean shift, resulting in grinding away the teeth on 5th over the years. Good luck. mike
