Vern, I was the first to respond to your post. I saw your number of posts and your signup date, I figured you have been around the red iron before. But when some one post a question like you did, it triggers the type responses you recieved. It seemed you were too lazy to even try to figure out what wrench would fit. It sounded like the post we all see where someone buys a tractor, has no manuals, wants to borrow your manuals, and cannot figure out how to check the oil...
Now we have that out of the way, there are two options for the tight clearance. If you have more than one wrench in the given sizes needed, you can grind one down in thickness to fit. The second option is to bite the bullet and spend some cash on a set of "service wrenchs" or "pump wrenchs". The are a little shorter, thinner, and wider than standard wrenches. They are used for applications like changing the fan belt on a SA.
Hang in there Vern, and do not take it personally. Hope you get the belt changed out.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
