Re: Loader Problems
Posted by vm from WI on January 19, 2009 at 00:09:51 from (69.179.24.240):
In Reply to: Loader Problems posted by tcanthonyii on January 16, 2009 at 19:31:40:
Could it be the Hydraulic cylinder on one side might be bent, causing it to stick? Just a thought.One way to check is to remove the cylinder and use air pressure to expand and retract( if double acting),but be careful not to get sprayed by oil coming out of the cylinder holes, or even switch right and left cylinder on the tractor.
