Re: IHAVI
Posted by Hugh MacKay on January 19, 2009 at 02:40:36 from (216.208.58.118):
In Reply to: IHAVI posted by Doug Orndorff on January 18, 2009 at 19:18:21:
Doug: You haven't indicated what you believe makes this tractor an I or Industrial. Yellow paint alone does not make it an Industrial. Could it be an AV with the heavy front axle, in fact I think most if not all AV had the heavy axle.
Does it have the foot throttle? What do the model and engine serial indicate on the flat surface below number 1 spark plug? Should be stamped letters and numbers on that flat surface.
  • Re: IHAVI doug orndorff 18:29:46 02/01/09 (0)
