Re: Help in building/plumbing lime spreader...
Posted by Clefus on January 19, 2009 at 13:13:47 from (98.21.20.155):
In Reply to: Help in building/plumbing lime spreader... posted by Clefus on January 17, 2009 at 20:48:55:
Thanks a lot for the reply...
I still plan on putting a new pump on the tractor due to the fact I bought a 2250 loader this winter....
I had problems with it last year lifting the plows and discs after the oil got hot...
I think I will go the pto driven pump route...too bad I got rid of one last fall when I traded a dozer pump with cylinder and resevoir
...thought I would never use that again..hmm dummy me....
I'll update this topic when I get it put together....trying to think of other uses for the pto pump rather than just tied up to the lime spreader....
The 2250 loader came with its own spool valve so I was
going to put in a priority valve before the hyd block on my 560 to plug the loader into and use the tractor pump ...the loader is a quck mount ...
Thanks again
Dave
