Re: Front axel on 806
Posted by caterpillar guy on January 19, 2009 at 17:51:10 from (64.12.116.73):
In Reply to: Front axel on 806 posted by Larry B on January 19, 2009 at 17:20:49:
A machine shop can bore the old boss out. And either press a new sleeve in, or they can cut the old hole out, and weld in a new piece. Like taking a heavy pipe and welding in the size of the new pin so they are tight to tolerence. A grease fitting will have to be drilled and tapped to be able to grease it.
