Posted by Lee in Iowa on January 19, 2009 at 19:35:41 from (66.172.198.89):
In Reply to: Front axel on 806 posted by Larry B on January 19, 2009 at 17:20:49:
I've fixed two of these with a new tube through the center of the axle. It is not a standard size so the ends have to machined out for the bushings. Which is better than the factory because the bushings cannot slide to the center when you put the pin in. On one the wide front was off and the guy at the shop cut the old one out and welded the new one in. The other one was under the tractor when I put it in. I jacked up the tractor and took the pin out and jacked it up high enough to cut the old tube out. Then I set the new tube in and let the tractor down enough to line it up and put the pin in. Then I tack welded the tube to the axle when I thought it was lined up right. I jacked it back up and welded it good. I had a hydraulic jack and splitting stands under the tractor when I was working on it and still tried to keep from getting clear under it. Lee
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
