Re: BD-154 Fuel Pump Problem( what am I missing challenge?)
Posted by BMD on January 19, 2009 at 20:15:46 from (65.254.172.6):
In Reply to: Re: BD-154 Fuel Pump Problem( what am I missing challenge?) posted by M Miller on January 19, 2009 at 13:23:17:
Thank you for the reply also! That tells me that is a more common problem that I first thought.I could not find and reference to that problem anywhere on the Internet or in this forum.There probably are very few "new" problems on a 30+ years old tractor that someone has not seen before
Thats sort what I was planning to try. using a 3.5 psi electric pump and a inline filter on the pumps inlet side. Will probably play with trying to get the mechanical to stay on the cam but I not holding out much hope of success.
Again thank you for your input. With Seeing Red's and your input I feel like thats what my problem is and fairly easily resolved.
BMD
