Re: oil pan gasket removal
Posted by wayne in MN on January 20, 2009 at 07:45:37 from (71.146.21.74):
In Reply to: oil pan gasket removal posted by Blackland Dan on January 20, 2009 at 06:13:15:
You likely have the tool already; take the largest mill file you have & use the square end for a scraper. It will not get dull, has weight behind your pressure, & does a great job on stubborn areas. Be sure to have a handle in place or you will likely poke a new opening into your palm.
Plus, you can use the filing part of your "new" tool to dress up or finish the job. Remove the handle so it will lay flat on the gasket surface.
Enjoy!
