Re: Where to buy pipe for exhaust manifold
Posted by charles todd on January 20, 2009 at 16:02:31 from (205.242.95.138):
In Reply to: Where to buy pipe for exhaust manifold posted by Chad504 on January 20, 2009 at 06:11:55:
I see that you already bought a nipple... I used a scrap piece of 2" conduit (Rigid) and threaded it. I think I cut mine 12"-13" long tip to tail.
Good luck removing the old one if you have not already... That can be interesting.
Charles
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
