Re: Engine kits for Farmall 300
Posted by Janicholson on January 20, 2009 at 19:11:18 from (64.83.227.252):
In Reply to: Engine kits for Farmall 300 posted by IHRedRules on January 20, 2009 at 19:00:08:
Using Tisco Kits from this sight, a 300 can be enhanced in displacement to that of a 350. The higher compression kits are also desirable. Fire crater/High altitude/Pop up/stepped head are names given to dome topped pistons making higher HP. This sight has had good reviews on engine kits (See Parts Store to the left on this page. H output can also be improved with a SH or 350 carb and cam shaft (one or both) JimN
