Posted by Janicholson on January 21, 2009 at 07:10:02 from (199.17.6.128):
In Reply to: Re: what is the TA posted by travz500 on January 21, 2009 at 06:53:51:
Not quite on both counts. If it is good, it is the same as using a powershift and getting in a hard pull. As the engine RPM begins to drop lower than maxtorque/HP ballance, (lugging) the TA is shifted to Low range with a single purpose lever. The lever is moved swiftly from one to the other position like a light switch. The tractor engine should increase in RPM and the speed might stay the same on the ground, or actually increase if the engine picks up enough. The TA is like down shifting an 8 speed Powershift one gear. No clutch pedal action is needed.
If it is bad, or mis adjusted, pulling it back into Low range under load will possibly cause it to slip as though it was in neutral (which in a sense it is) then (as the Tractor Vet indicates) it can grab from that neutral and jerk forward suprizing the operator quite a lot. So keeping your foot over the clutch pedal is prudent if it goes into a false neutral. The TA is not as convienient as a full powershift trans, but provides a long and usually trouble free life in High HP tractors on down to 30 HP range. It also has the efficiency of a mechanical system rather than fluid couplings found in --some-- other systems. I hope this helps. Best of luck. JimN
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
