Re: Dwell on IH 666 with C291
Posted by karl f on January 21, 2009 at 08:42:47 from (209.188.106.159):
In Reply to: Dwell on IH 666 with C291 posted by JMS II on January 21, 2009 at 08:26:10:
Might be the normal throttling up. Tractors do not (generally) have accelerator pumps to give that extra shot of fuel when you gun it.
if it runs ok under load and wide open you might not have any problems.
wouldn't hurt to do a wiggle test on the distributor shaft though, any slop means your adjustments will be in vain.
karl f
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
