Re: Farmall Hydrauic Problems
Posted by mkirsch on January 21, 2009 at 09:02:34 from (64.80.108.55):
In Reply to: Farmall Hydrauic Problems posted by 697447 on January 21, 2009 at 08:51:24:
Did the loader go up?
If so, the vents should be plumbed to the fill pipe on the belly pump, because they act as auxiliary reservoirs for the hydraulic system.
This is common on older straight-arm loaders with one-way hydraulics. Without the extra oil from the tops of the cylinders, the system would not have enough to lift the loader all the way up.
